meanjeanslo
Dec 18, 2024Guide
Readyshare no longer available - asking for credentials, but not supposed to
My router's Readyshare has suddenly stopped working. When I try to access it, it prompts for credentials which it should not be doing. I reset it to factory and it still isn't working. Firmware...
- Dec 18, 2024
This is what solved it for me and the video where I got the information:
Enable insecure guest login policy
Start > Run > "gpedit.msc"
Computer Configuration > Administrative Templates > Network > Lanman Workstation
Select: "Enable insecure guest logins"
Change to Enabled and Apply
close window and then try again.
This absolutely worked for me!
meanjeanslo
Dec 18, 2024Guide
Dec 18, 2024Guru - Experienced User
Glad you got it working and letting us know the fix. Seems like MS may have changed the log in process on an update. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
