jljohnson51
Feb 08, 2025Aspirant
READYSHARE, RAX 54v2, will not connect to computer
I had a Netgear router for 20 years work great but it finally quit. Purchased a new Netgear to replace, the Nighthawk AX6, I purchased this as it provides a connection for the internet as well as an in-home connection, but it also provides Readyshare so I can connect my storage unit to keep my files off of the computer. When I follow the instructions, Start, RUN, and enter \\readyshare, I receive an error message (an extended error has occurred).
That is in Windows?
That is where to look for the solution.
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
Here's where to look in Windows 11:
- Settings
- System
- Optional Features
- More Windows features
Then there is the Public/Private network thing in Windows.
- Network and Internet settings
- Ethernet
- Properties
- Private network
Disclaimer: Just another user with time on their hands.
- jljohnson51Aspirant
My computer is set to private. You directed me to More Window Features, but I know nothing about this area and have no idea what to turn on or off. Still receiving the message: (an extended error has occurred)
Did you follow the Community link I provided?
