jljohnson51's avatar
jljohnson51
READYSHARE, RAX 54v2, will not connect to computer
I had a Netgear router for 20 years work great but it finally quit. Purchased a new Netgear to replace, the Nighthawk AX6, I purchased this as it provides a connection for the internet as well as an in-home connection, but it also provides Readyshare so I can connect my storage unit to keep my files off of the computer. When I follow the instructions, Start, RUN, and enter \\readyshare, I receive an error message (an extended error has occurred).
  • michaelkenward's avatar
    michaelkenward
    That is in Windows?
    That is where to look for the solution.
    Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
    Here's where to look in Windows 11:
    • Settings
    • System
    • Optional Features
    • More Windows features
    Then there is the Public/Private network thing in Windows.
    • Network and Internet settings
    • Ethernet
    • Properties
    • Private network
    Disclaimer: Just another user with time on their hands.
    • jljohnson51's avatar
      jljohnson51
      My computer is set to private. You directed me to More Window Features, but I know nothing about this area and have no idea what to turn on or off.  Still receiving the message: (an extended error has occurred)
