Bear100
Jul 07, 2024Aspirant
Rebooting every day?
Hi, I have a RAXE300 in place of my Sky standard router, I have ultra fast fibre with Sky. Fitted the new router Friday and every day sometimes twice the router looses internet with orange light and ...
Bear100
Jul 08, 2024Aspirant
I have the standard BT ONT with 3 green lights connected to the Nighthawk RAXE300
michaelkenward
Jul 08, 2024Guru - Experienced User
Several boxes fit that description.
Openreach modem (ONT) explained: Ports and models available | BT Help
The reason for asking is that some come with built-in router features.
When you installed the RAXE300, did you reset the thing and set it up from scratch. (Where did the Sky standard router come from?)
- Bear100Jul 08, 2024AspirantThanks for the link, looks like I have the Nokia version is that good or bad?
Yep rest to factory with the tiny rest hole on the rear and set up from scratch.
The sky Q hub was sent by Sky.- FURRYe38Jul 10, 2024Guru - Experienced User
Is the Sky Q Hub router in the mix or just the modem and RAXE router?
The sky Q hub was sent by Sky.- Bear100Jul 10, 2024AspirantThe sky hub has been removed, Nighthawk connected to the Nokia modem
