digitalis32
May 05, 2021Tutor
Recent RAX120 Firmware V1.2.0.16 rendered 2.4Ghz radios inoperable.
On my RAX120 Router the 5G wireless works perfectly however the recent firmware update seems to have rendered the 2.4G radios inoperable. I have a considerable investment in IoT devices which rely heavily on this frequency band, and the loss of basic 2.4G connectivity from such an expensive device has been intesnely aggravating.
I have done a factory reset (base firmware was V1.0.2.136 ) and 2.4G is still inoperable, I have tweaked a few settings in the hopes of resolving any conflict with networks surrounding my house. I tried activating a guest network soley on 2.4Ghz which according to multiple devices that operate on that band was non-existant, the router persistently remains silent on that frequency.
you can downgrade the firmware. Maybe the new update caused issues.
Simply download the old firmware and follow the manual update process but use the older firmware
Already done that, rolled back to the Base firmware and post downgrade I performed a reboot to ensure the device was reset properly.
Your best option is to drop Netgear and buy another brand, I did.
