gs550t1981
Jul 08, 2020Tutor
recent update rax40
I did the update the router called for and now I need to reset the router atleast 5 times a day to get it working again. B4 the update it was fine. I am working from home right now so its kind of a bi...
gs550t1981
Jul 09, 2020Tutor
Yes. I was just unplugging it. How do I do a full reset?
Jul 10, 2020Guru - Experienced User
You can do it through the gui menu or using the hardwired button.
menu----navigate to advanced-----administration-----backup-----erase
hardwired-push and hold reset while powered on for 7-15 seconds.
- scott2003lhsJul 10, 2020StarI have had disconnects and devices claiming 5ghzs has no internet on the prior firmware and this one. Did full factor reset before both. Guru, do you have any tips. I went through netgear support and nothing fixed this. I may bite the bullet and do a different brand. Never had a router so buggy in my life. Always used Netgear...
- plemansJul 10, 2020Guru - Experienced User
scott2003lhs I see you've started your own thread and even had a moderator responding to you. Did you contact them for assistance?
- scott2003lhsJul 10, 2020StarYes. They contacted me and took me through steps even losing newest firmware with full resets. It didn’t fix the issue. I know the software teams are working hard, but given the amount of people with similar issues and threads, I wish a mod would give us an estimated time for a fix. I can’t keep having disconnects working at home and having to reboot the router.
