gs550t1981
Jul 08, 2020Tutor
recent update rax40
I did the update the router called for and now I need to reset the router atleast 5 times a day to get it working again. B4 the update it was fine. I am working from home right now so its kind of a bi...
Jul 10, 2020Guru - Experienced User
scott2003lhs I see you've started your own thread and even had a moderator responding to you. Did you contact them for assistance?
scott2003lhs
Jul 10, 2020Star
Yes. They contacted me and took me through steps even losing newest firmware with full resets. It didn’t fix the issue. I know the software teams are working hard, but given the amount of people with similar issues and threads, I wish a mod would give us an estimated time for a fix. I can’t keep having disconnects working at home and having to reboot the router.
- plemansJul 10, 2020Guru - Experienced User
Maybe its a bad device.
I'd recommend posting on your original post. Your issue could be different than the OP's and confuse their issue. Plus you've already got the moderator that'll get notices about your post on there.
- scott2003lhsJul 10, 2020StarThanks. I will :)
- JACKSFCAJul 12, 2020Initiate
I'm having the same issues, after a day or so the router drops wifi connections, If I try hardwire I get no ip address, although I get link lights on Network adapter, Lights are on for power, internet and 2,4 and 5 ghz. I also found it boardcast the ssid, but when I tried to connect it say wrong password, then I lost all ssid discovery of the router 2.4 of 5 ghz. I have done factroy resets multipe times with the reset botton, and via the gui. I using the to work from home. This is very, bad. We need a fix, either roll back to working version of firm ware, or something. Replace the router with another device of different device, asap. I would like support from netgear to address my problem.
