gs550t1981
Jul 08, 2020Tutor
recent update rax40
I did the update the router called for and now I need to reset the router atleast 5 times a day to get it working again. B4 the update it was fine. I am working from home right now so its kind of a bi...
scott2003lhs
Jul 10, 2020Star
Yes. They contacted me and took me through steps even losing newest firmware with full resets. It didn’t fix the issue. I know the software teams are working hard, but given the amount of people with similar issues and threads, I wish a mod would give us an estimated time for a fix. I can’t keep having disconnects working at home and having to reboot the router.
Jul 10, 2020Guru - Experienced User
Maybe its a bad device.
I'd recommend posting on your original post. Your issue could be different than the OP's and confuse their issue. Plus you've already got the moderator that'll get notices about your post on there.
- scott2003lhsJul 10, 2020StarThanks. I will :)
