gs550t1981
Jul 09, 2020Tutor
recent update rax40
I did the update the router called for and now I need to reset the router atleast 5 times a day to get it working again. B4 the update it was fine. I am working from home right now so its kind of a bi...
Jul 10, 2020Guru - Experienced User
Maybe its a bad device.
I'd recommend posting on your original post. Your issue could be different than the OP's and confuse their issue. Plus you've already got the moderator that'll get notices about your post on there.
scott2003lhs
Jul 10, 2020Star
Thanks. I will :)
