dan147's avatar
dan147
Recommend a pair of routers for my fixed wireless setup
Hi All, Im looking for recommendations for what do buy for my setup.I have two locations, a house and shop. between the house and a shop, there is a fixed-wireless solution already in place, a pair o...
  • Razor512's avatar
    Razor512
    Oct 21, 2021
    For your use case, for the nighthawk app to manage both without having to switch any networks, the RAX50 would have to be put into AP mode.
    Beyond that, it should all work smoothly with a setup such as RAX120 from the main home > Ethernet> Ubiquiti ~beam product> Wireless point to point> Ubiquiti ~beam product>  Ethernet> WAN port of RAX50 in AP mode.
