preynoso
Dec 11, 2019Aspirant
Recommendation between AX4 VS X10 for new buy
Hello guys, wanted to see what your thought were between buying an X10 or buying one of the new RAX40 WiFi 6 routers. My application is a medium home, running 1gps google fiber so I’d like to take adv...
michaelkenward
Dec 12, 2019Guru - Experienced User
Try reading the messages here already.
There are more than enough to give you some clues as to the user experiences with these devices.
For " least hassle" investigate the Orbi range.
- preynosoDec 12, 2019AspirantI have been reading them, pretty much they say both are a piece of crap.... lol but some people have posted their X10 gave them better speeds than the new AX4/AX8/AX12 so my question still remains. Any advice would be appreciated.
- digitsnbitsDec 12, 2019Apprentice
I've used both the AX4 and a RAX80. Both are absolute garbage especially the AX4. The AX4 got returned within a couple of days. The RAX80 is sitting in a box, can't return it and too frustrating to use.
If you're looking at an AX4 try the Asus RT-AX58U (Best Buy, similar specs) which is a way better experience and actually works as advertised. Or the Asus RT-AX88U which at this point blows the doors of of anything Netgear makes, which is what I'm using now. Netgear blows.
