millewg001
Apr 29, 2021Aspirant
Regular loss of network connectivity
I have an RAX120 installed running with Spectrum 300mbs service with their MODEM. On a regulary basis, I lose all internet connections and random times. (3am, midnight, 4:30pm, etc). I've been assu...
Apr 30, 2021Guru - Experienced User
When you have the outage, are you still able to access the routers interface?
And after that, are you able to ping/log into the modem?
- millewg001May 03, 2021Aspirant
No, the only way I can connect is to reboot the router. I have been having a running issue attempting to determine if my problem is the router or Spectrum's model. The last 3 calls, my ISP service appears to be fine (per Spectrum Customer Suport) and I needed to either replace the cable between the router / modem, or reboot the routher. Both times, I was able to reestablish normal internet connection.
- plemansMay 04, 2021Guru - Experienced User
You say the only way to connect it to reboot the router.
What is happening when it drops?
Does your wifi signal disappear?
Does it say "connected, no internet"?
Are wireless and wired devices able to ping the router?
What are the led's doing on it when it goes down?
- millewg001May 06, 2021Aspirant
What is happening when it drops? I cannot access the internet, either through a wireless or a wired connection.
Does your wifi signal disappear? I am assuming the wirless signal is that on my phone or mac. It does not.
Does it say "connected, no internet"? When I turn my wifi offf then on on my ipad, it tells me "connected, no internet".
Are wireless and wired devices able to ping the router? I did not try this. I did, however, attempt to access my router from my mac and it would not let me access the routher.
What are the led's doing on it when it goes down? The LED's appear to be operating as though everything is normal.
IT happened this am (again). I'll attempt to ping the router the next time it occurs. One thing I noticed though it the NTP time was not set properly (DST not set). I reset and rebooted.
