millewg001
Apr 29, 2021Aspirant
Regular loss of network connectivity
I have an RAX120 installed running with Spectrum 300mbs service with their MODEM. On a regulary basis, I lose all internet connections and random times. (3am, midnight, 4:30pm, etc). I've been assu...
Apr 30, 2021Guru - Experienced User
When you have the outage, are you still able to access the routers interface?
And after that, are you able to ping/log into the modem?
millewg001
May 03, 2021Aspirant
No, the only way I can connect is to reboot the router. I have been having a running issue attempting to determine if my problem is the router or Spectrum's model. The last 3 calls, my ISP service appears to be fine (per Spectrum Customer Suport) and I needed to either replace the cable between the router / modem, or reboot the routher. Both times, I was able to reestablish normal internet connection.
- plemansMay 04, 2021Guru - Experienced User
You say the only way to connect it to reboot the router.
What is happening when it drops?
Does your wifi signal disappear?
Does it say "connected, no internet"?
Are wireless and wired devices able to ping the router?
What are the led's doing on it when it goes down?
- millewg001May 06, 2021Aspirant
What is happening when it drops? I cannot access the internet, either through a wireless or a wired connection.
Does your wifi signal disappear? I am assuming the wirless signal is that on my phone or mac. It does not.
Does it say "connected, no internet"? When I turn my wifi offf then on on my ipad, it tells me "connected, no internet".
Are wireless and wired devices able to ping the router? I did not try this. I did, however, attempt to access my router from my mac and it would not let me access the routher.
What are the led's doing on it when it goes down? The LED's appear to be operating as though everything is normal.
IT happened this am (again). I'll attempt to ping the router the next time it occurs. One thing I noticed though it the NTP time was not set properly (DST not set). I reset and rebooted.
- millewg001May 24, 2021Aspirant
An update on this issue. I recently completed a factory refresh and the router seems to have stabilized. It has been running steady now for about 5 days so I am cautiously optimistic.
My original question remains though. When I have network issues, what tools/procedures are available to determine whether my router or ISP modem or my ISP service is cauising the outage. I can call my ISP and have them check my modem/service to determine if I have a problem but diagnosing the model seems prolblematic. I would appreciate links to sources to help me understand router diagnostic issues, log recordings, etc. Any suggestions.
Also, it appears once I reboot my router, all logs are lost. Can these logs be saved on a regular bases (say on my PC) to allow me the option of reviewing the logs just prior to the outage?
