lagr
Jan 14, 2020Guide
Remain logged in in the admin UI?
Two quick questions: 1. The timeout for staying logged in in my new router is very short. Is there a way to increase it? 2. I want a non-7-bit character (ö) in my guest network name. I found ...
Christian_R
Jan 15, 2020NETGEAR Employee Retired
Hi lagr,
Welcome to the community!
1. This is by design and there is no way to increase the time logged into the admin UI.
2. We recommend that you use valid characters in the guest network name.
Christian
lagr
Jan 25, 2020Guide
That is a genuinely stupid design desicion. I live by myself and am the only user of this router. Exactly why should I have to login again and again when I want to administrate this router?
Why is a 8-bit character "not valid"? It works fine on my previous Airport.
- labattJan 25, 2020Mentor
Just a question. Why are you constantly "adminstrating" the router? Once setup it should just work. I may login to my network once a week just to see if there is anything in logs, but my network just purrs along without my intervention.
- lagrJan 25, 2020Guide
I am not. but ATM I am setting it up from scratch and that means that I have to google and readup quite a bit and everytime I return to the router I am kicked out.
Furthermore, in the future, when there are FW upgrades, I am gonna repeat this and look up new functions and other changes.
What is the advantage in my situation to be kicked out all the time? What does this policy remedy?
Like most web and device logouts it has to do with security. Take your bank for example. Bet they have a timeout for no activity. Would not want someone else setting down and transfering my money to their account. So same at a lower scale with the router. Understand the frustration haviing to log back in when doing research and then when you are ready you are logged out. Been there.
