lagr
Jan 14, 2020Guide
Remain logged in in the admin UI?
Two quick questions: 1. The timeout for staying logged in in my new router is very short. Is there a way to increase it? 2. I want a non-7-bit character (ö) in my guest network name. I found ...
labatt
Jan 25, 2020Mentor
Just a question. Why are you constantly "adminstrating" the router? Once setup it should just work. I may login to my network once a week just to see if there is anything in logs, but my network just purrs along without my intervention.
lagr
Jan 25, 2020Guide
I am not. but ATM I am setting it up from scratch and that means that I have to google and readup quite a bit and everytime I return to the router I am kicked out.
Furthermore, in the future, when there are FW upgrades, I am gonna repeat this and look up new functions and other changes.
What is the advantage in my situation to be kicked out all the time? What does this policy remedy?
- labattJan 25, 2020Mentor
Like most web and device logouts it has to do with security. Take your bank for example. Bet they have a timeout for no activity. Would not want someone else setting down and transfering my money to their account. So same at a lower scale with the router. Understand the frustration haviing to log back in when doing research and then when you are ready you are logged out. Been there.
- lagrJan 26, 2020Guide
Yes, of course that is the motivation but it is not a very wellthought motivation. I would be much more concerned if someone accessed my Gmail or Facebook account than my router, and they both allow me to remain logged in for months (or years) at the time. Even this site allows that.
- michaelkenwardJan 26, 2020Guru - Experienced User
After a router is set up and running, most people rarely go back in and mess around. That's the whole point of setting it up.
However, if you want to monitor activity and control some basics, such as the wifi, then the desktop genie for your operating is your friend.
If you want the desktop genie for Windows, for example, start here:
genie Landing Page | Apps | Discover | Home | NETGEAR
You may have to dismiss an annoying pop-up that tries to push a mobile app down your throat.
