pmrii
Sep 30, 2022Follower
Remote connetion of Nighthawk AX3000 to T-Mobile gateway system
I have a Netgear Nighthawk AX3000 model: RAX40-100NAS router. Some devices are wifi and others are hardwired to a switch box which in turn connects to the router. My cable ISP lost its local contra...
Sep 30, 2022Guru - Experienced User
Check the routers web page under Advanced Tab/Advanced/Router mode for Bridge mode. This mode you can connect the RAX wirelessly to the ISP routers wifi as a client then you can connect wired devices to the RAX. There is AP mode but that needs a wired connection to the ISP router.
