Fixitplease02
Jun 10, 2020Initiate
Remove Netgear Armor Trial
I want to know how to delete anything associated with Netgear Armor, which somehow, it got activated for a 30 day trial. I know what it is and you couldn't pay me to use that service, much less me pay...
psychopomp123
Jun 11, 2020Luminary
On the Nighthawk smartphone app, go to settings > security and turn off the toggle for 'enable Netgear armor'.
Fixitplease02
Jun 12, 2020Initiate
But there isn't a way to just cancel the subscription and be done with it? There is nothing that I have seen anywhere to cancel or remove. Turning it off is fine but I want it gone! Lol. I paid $600 at Best Buy for that router a few months back and then suddenly I'm being hassled by a subscription service that I don't want or need, with no way to stop it.
- RajaDajaJun 12, 2020LuminaryWell,
If you have backup prior to installing Armor. Initially I didn’t install Armor after the new firmware update. But the only way to get rid of Armor other than restoring the router back to a previous point is a Factory Reset.
