smokin007's avatar
smokin007
Removing Arcadyan Smart Modem and Installing Nighthawk Mesh WIFI6 AX1800?
G,Day Netgear Community,
                                             I have purchased the above modem / WIFI6 Mesh system...I had an "Arcadyan Smart ac Modem" and I am simply trying to remove the old Arcadyan and set up the Netgear Mesh system... I want to use WIFI with the new system as I have done with the previous modem but it simply wont connect??.
           I want to power the new modem by removing the old one entirely and the sats at the sametime and use WIFI throughout the house...My laptop recognise's the Netgear modem but will not connect at all ... It asked when installing the modem through the settings within the lapstop for the modems password which I typed in and it wont connect ...I have tried a factory reset several times along with sycn and nothing changes... If I put the old arcadyan back on it connects within minutes but as soon as I put the new modem on it knocks the internet out???..
           I simply won't to plug it in, turn the sats on, type in my password on my laptop and hope for interent?... Not happening!!.. I have tried the mobile app and it wont connect either?...I have read everything and I have a headache as this has been 4.5hrs now... Any ideas or should I return the Mesh WIFI6 and get a refund?... Thank you very much...
Regards
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi smokin007,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    http://www.netgear.com/support/contact.aspx
    Christian
    • smokin007's avatar
      smokin007
      Christian,
                      Thank you for taking the time, to reply, to my post and question ... I will try one more time then perhaps ask support...Hope to get around to setting the "Mesh" up Tues 8 Sept 20 and I will included you when I reply... Once again thank you...
      Regards
      • schumaku's avatar
        schumaku
        What kind of Internet connection, which ISP(often very informative), and what exact type of Arcadian deivce are we talking of here? The Nighthawk Mesh is an Ethernet router, not a modem (e.g. for ADSL or VDSL or CableTV).
