RW12
Dec 12, 2020Aspirant
Replacement for AC1900
Looking to replace-upgrade a nighthawk ac1900 and R7000 with something that has the same or more coverage area. More concerned about getting coverage than speed and few Enet ports as I have hard wire ...
RW12
I typed incorrect I have the Nighthawk R7000 AC1900 which has to be reset once a week that was paired with the Nighthawk EX8000 extender, the light on the extender is what is blinking, tried off/on, reset, factory default ext but no luck. So was looking to replace/upgrade.
