RW12
Dec 12, 2020Aspirant
Replacement for AC1900
Looking to replace-upgrade a nighthawk ac1900 and R7000 with something that has the same or more coverage area. More concerned about getting coverage than speed and few Enet ports as I have hard wire ...
michaelkenward
Dec 13, 2020Guru - Experienced User
RW12 wrote:
I did buy the RBK753 AX4200, have not opened as have concerns it will not have same coverage area.
If that doesn't cover it, you must live in a big mansion.
You can always add extra satellites.
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
That will give you some idea of the area you can expect to cover.
- RW12Dec 13, 2020Aspirant
No mansion just the way the area I want to cover is laid out like a U. We have a garage/workshop on one side, house in middle and outside patio area on other side the house. Thanks
