Kurt0375
Oct 20, 2020Follower
Replacement Power Supply
Hi, Recently got a use RAX200 but didn't come with a power supply, slight issue I have looked everywhere and can't seem to find a compatible power supply with the correct connector, I have found/ pu...
Christian_R
Oct 23, 2020NETGEAR Employee Retired
Hello Kurt0375,
I would recommend contacting the reseller of the device or you may try contacting our support team.
https://www.netgear.com/support/default.aspx
Christian
- FlatheadLakeJan 05, 2021Guide
Did you ever find a source for a DC plug eithout the center pin?
I need to replace the DC 7.4mm OD x 5.1mm ID (5.0 mm actual) barrel connector without a center pin that is on my Netgear Nighthawk CAX80 power supply. Cannot find this plug anywhere and so far no help from Netgear support.
