Sinloy
Mar 19, 2023Aspirant
Replacement router
I current have a R6400 router. My ISP is offering a 1 gig connection to the home. My R6400 doesnt go that high on the Wan port. Which Netgear router would be best to support this 1 gig connection to...
michaelkenward
Mar 19, 2023Guru - Experienced User
Sinloy wrote:
I was looking at the RX35 or 40 for a replacement would this be a good choice?
plemans has given you the best answer to the original question. Bit it you are really lusting after a new router, and want to use the new service as an excuse, for get about the speed and look at the other things you want to achieve. Maybe better WiFi?
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
WiFi Range Extenders: Boost Your WiFi Range | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
My first move would be to stick with the existing router, follow what plemans suggests and see how that works out.
