theMPG
Dec 13, 2021Tutor
Replacing my BT Home Hub 6 with DrayTek Vigor 130, then connecting to my Nighthawk RAX200
Replacing my BT Home Hub 6 with DrayTek Vigor 130, then connecting to my Nighthawk RAX200, step by step guide if possible. Hi. Looking for some not-too-techie guidance and help, if possible....
michaelkenward
Dec 14, 2021Guru - Experienced User
theMPG wrote:
My plan is:
- I replace my existing BT Home Hub 6, with a DrayTek Vigor 130 modem
- then, attaching my Netgear Nighthawk RAX200 to my new DrayTek Vigor 130 modem.
- Can anyone give me 'an idiots guide' for how to configure my RAX200 for perfect harmony, between the Vigor130 and the RAX200 units.
- do I perform a factory reset of the RAX200, so automatic configuration can sense the v130 modem and pick up up those settings- do I perform a factory reset of the RAX200, and manually set-up each section? If so, how... what should the settings be...?
The reset is probably a good idea. Either that, or, if it has already been set you to run on BT, just take the RAX200 through the Internet Setup Wizard.
I also understand the Vigor will be in Bridge mode, which then leaves the RAX200 to manage the DHCP, and I have obtained then PPPoE information for my BT Broadband provision.
It looks like the DrayTek comes in bridge mode by default. Indeed, I see no sign that it can do anything of a router nature, unlike the Netgear DM200.
As long as you can get the DrayTek to work with BT, it should be a very simple process.
right order.
My first move would be to get the modem to work before even thinking about the router. Connect a PC to the modem. Set that up and confirm that you have a good Internet connection. Apply any firmware updates for the modem. These things can be a bugger to get into once they sit in front of a router.
Then add the router.
Ignore exhortations from Netgear to use an app to set the router. If possible, use the browser graphical user interface (GUI).
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
- theMPGDec 14, 2021Tutor
Amazing. Thanks so much... at least I wasn't too far off plan.
I take note of your suggestions though, and am going to take my time, do this slowly, and do it right... he says. ;-0
