Not-Maven
Aug 15, 2020Follower
Request to update and action results in Netgear Nighthawk X6 AC3200 TriBand disabled.
Email Request by Netgear to update Nighthawk X6 AC3200 Tri-Band Router results in Router being disabled. This fits no category of customer service. Does anyone know how to reach Netgear on this issue...
rinthos
Aug 16, 2020Luminary
Not-Maven wrote:Email Request by Netgear to update Nighthawk X6 AC3200 Tri-Band Router results in Router being disabled. This fits no category of customer service. Does anyone know how to reach Netgear on this issue? The product was great until updated.
I'm going to guess you got an email notification regarding a firmware update, and ran the firmware update and it broke your router and you want to contact Netgear?
To do so: https://www.netgear.com/support/contact.aspx
Assuming you've done decent troubleshooting, but if not you can try factory resetting your router, and then trying the TFTP update method.
IF still no go, and you are under warranty, you can request an RMA on that site above.
Factory Reset: https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
TFTP Update method: https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
- michaelkenwardAug 17, 2020Guru - Experienced User
If that really is what the question is about, I caution against using that last link. The advice is out of date and likely to cause problems for people who have to go out and get third party software. It also adds unnecessary complication.
Instead use this:
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This explains how to use the TFTP clients that comes with Windows. There may also be a Mac equivalent.
There is more severe, recovery reset, that you could try:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
If it works, you may be able to use the usual method to flash the firmware again.
Download the latest firmware for your device – or an older version if that is what you want – and read the Release Notes for how to install it.
If that fails, you are into TFTP country.
This isn't the easiest operation, so if you are forced to use it, you could try a web search to find videos that guide you through the process.
The good news is that TFTP has rescued many a dead device.
