PMac23
Jul 23, 2021Follower
Requests to Internet fail temporarily on Device attached to RAX80 since recent update
We believe since we have updated the firmware to Version V1.0.4.120_1.0.61 (or the update before that) we have had some stability issues.
I can confirm it is a router issue as we have a second one which is independent (both connect to our ISP separately) and has no such issues.
These are the symptoms:
- Some mobile phones (not all it seems) connected to the router will complain there is no internet available
- On a wired connection to the router from chrome/edge it will complain it cant load the page with some sort of not found error... the browser will self retry and then load the page successfully.
- Note that this also occaisonally causes stylesheets not to load...
This router was not cheap and is less than 12 months old (just out of support)... getting a bit frustrated.
1 Reply
- Christian_RNETGEAR Employee Retired
Hello PMax23,
Can you revert to the previous firmware version and let us know if your issue persists.
Christian
