Whipsnade
Apr 23, 2023Aspirant
Require ethernet connection for admin login
I have a AX4300 WiFi Router, Model RAX45. https login doesn't seem to really be supported even though Web Services Management has a check box for "Always use HTTPS to access router." If this is che...
Apr 23, 2023Guru - Experienced User
No. Login supports both ethernet and wireless connections for support flexibility.
