Deepthi_
Apr 03, 2023Follower
Require help regarding WPA2 and WPA3 commands from router telnet console
When i tried to enable WPA3 security from the raxe500 netgear router console using the commands "sae_pwe_hnp_enable" and "wpa_auth 0x40000", getting an error as dhd unsupported with error code. But t...
michaelkenward
Apr 03, 2023Guru - Experienced User
Where does telnet enter the picture? Does that work on the RAXE500?
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk with WiFi 6 (AX) and WiFi 6E (AXE) Routers - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
