Stormygirl
Aug 11, 2022Aspirant
Reset button on used RAX120 not working
I purchased the net gear nighthawk rax120 on auction. I thought it was new but it was an Amazon return. No instructions in box. The app only works so far. The router name shows up on my phone but it’s...
Aug 11, 2022Guru - Experienced User
Possibly, if the long press or 303030 didn't work, i'd say its not in a good state or not responding.
Stormygirl
Thank you. That’s all I wanted to hear but from someone more knowledgeable than me.
- plemansAug 11, 2022Guru - Experienced User
have you tried using a hardwired in pc/laptop?
Are you able to get to the gui for the router with a hardwired in device?
