hawgdecker49
Dec 09, 2024Aspirant
Reset Nighthawk AX4 AX3000 WiFi Router(RAX35v2) Question
I have a: Nighthawk AX4 AX3000 WiFi Router(RAX35v2) that I purchased about 2 years ago based on a recommendation from this group. I on a scale from 1-10 I give it an 11!!! I presently have experience...
Dec 09, 2024Guru - Experienced User
Can reset by pressing the reset button in back for 15 seconds then release https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
Or use the ERASE button on the routers web page to factory reset the router:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
Then setup from scratch using a wired PC:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
While setting up, if you use same SSID name and password for the WiFi, then your devices will reconnect.
hawgdecker49
Thank you FLURRYe38!!!
- FURRYe38Dec 09, 2024Guru - Experienced User
Don't need the extra charater though. đ
Good Luck.
