additude
Mar 28, 2020Virtuoso
Revoked security certificate with remote login
I have a RAX120 for over a year now that has a remote login issue which I have been troubleshooting "as time permits". I have set the RAX120 up for remote login to a static IP; https//:x.x.x.x:8080. ...
SunshineFAM
Apr 23, 2020Aspirant
I have the same issue on a R9000. I am using a MacBook Pro to access a Windows 10 Home desktop remotely using teamviewer. I am accessing the router then locally through both MS Edge and Chrome. I have added the routers trusted certificate to Windows 10 certificate store as Netgear support indicates in their steps. The certificate shows it has been added to the store successfully and the certificate expiration is still current. The certificate always indicates revoked and I have tried https for all domain names on the certificate with no success. Any overide I have tried shows revoked certificate but is none the less an inconvenience as this needs to be corrected. Please Netgear fix this.
additude
Apr 23, 2020Virtuoso
It's still broken for me as well and the only bandaid I was able to figure out for my Windows 10 machine was:
"C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --ignore-certificate-errors https://your.wan.ip.here:8080
Where 8080 is the remote port. I think the default is 8080 ....
