Wreckstein
Oct 13, 2021Aspirant
Roku not being discovered on network
I have Nighthawk MR60 mesh system with one satellite. All my IP’s match my network. My Roku devices are on my network and appear in attached devices, they work just fine. The issue is the devices a...
Wreckstein
1.1
Oct 13, 2021Guru - Experienced User
??? What model gateway is the router connected to
- WrecksteinOct 13, 2021AspirantIt’s an Arris Surfboard DOCSIS 3.0
- plemansOct 13, 2021Guru - Experienced UserWhich isn't a model. There's a lot of different surfboards and some have integrated routers. What model is it?
- WrecksteinOct 13, 2021AspirantSB6190 to be specific
Are you using IPv6?
If you turn off the satellite (for testing) does it work?
