jonnysbazar
Feb 02, 2021Aspirant
Router AX12 RAX200 not conecting to internet anymore
ello guys got this modem July 6 2020 on amazon!The router is working, I can access the router login.. make changes, but not connecting to the internet anymore! I have to get a new one to work again!...
Christian_R
Feb 05, 2021NETGEAR Employee Retired
Hello jonnysbazar,
You may need to perform a factory reset your router by holding down on the reset button for 15+ seconds. You will need to run through the setup assistant again.
Christian
- jonnysbazarFeb 05, 2021Aspirant
Dit that buddy so many times! Got a router from other brand and works perfect!
3 router in 2 year buddy!
I don’t know why Netgear delivering routers with problems to people out there!reset the router is pretty easy!
Very sad and mad that I spend so much for this and its not working anymore!
