Sumiteru_Adachi
Dec 01, 2023Aspirant
Router becoming unreachable
Main issues I've been having is when I set up a vpn on the router and have it enabled, after a while the router becomes unreachable as in I can't get onto it anymore and the vpn breaks.
I still get Internet and everything else is fine but if I ever want to make changes again I have to reset the router to default.
Tried importing the config before it broke and doing it again but same result, don't have anything crazy set up other than 2 ports open and dynamic dns.
I've tried checking logs before it goes 'down' but that hasn't suggested anything, done a firmware update and no difference.
like to hope to assume this isn't a known issue where I can only have dynamic dns or a vpn.ut not both
Sumiteru_Adachi wrote:
Main issues I've been having is when I set up a vpn on the router and have it enabled, after a while the router becomes unreachable as in I can't get onto it anymore and the vpn breaks.Which VPN is this? OpenVPN? Something else?
What Netgear device do you have?
What modem/gateway/ONT sits between the router and the Internet?
- Sumiteru_AdachiAspirant
OpenVPN which iirc is on the advanced set up mnu
RAX 40I think the answer would be Openreach? michaelkenward
Answer to what?
That's the company that provides the Internet network in the UK.
