MINIMD
Jan 04, 2023Aspirant
Router blocking some websites
Router: RAX10 (latest firmware) 2 years have been used. It started happening two weeks ago. Technical level: Intermediate or advanced in troubleshooting The router is connected to 6 Windows/...
Jan 04, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Do you have IPv6 enabled on the router?
MINIMD
Router: Nighthawk AX1800 RAX10 (version 1.0.10.110)
Modem: Arris CM8200A
I did these steps:
""""Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn on computers and rest of network. """"
IP 6 is diable in Router.
