Daneph
Apr 03, 2024Aspirant
router cant access netgear account
setup new router yesterday through web page. today I login to router and wants netgear account. I go to login and just keeps saying "something went wrong". I can obviously get to my account here. in ...
- Apr 05, 2024
based on your statement no account is needed for routers I disconnected the router from the internet and got in.
kind of a pain but i got ports forwarded i was after in the first place. thanks for the help
Apr 03, 2024Guru - Experienced User
What browser are you using? Happening on MS Edge or Firefox?
Disconnect the router from the ISP modem and factory reset the router and setup from scratch:
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
See if you can get in to the routers web pages, then connect it to the ISP modem.
Please post the FW version if you can see this.
Daneph
I’m trying to avoid a reset and having to completely setup again
this is in edge
- DanephApr 03, 2024Aspirant
The fw as seen in app says 1.1.4.28
