barryfv
Aug 02, 2020Follower
Router compatibility Choice
I have a Nighthawk X6S AC 3000 Tri-Band WiFi Range Extender EX8000 and am considering buying either an AX6000 Nighthawk AX8 8-Stream Wifi 6 router or an AX6000 Nighthawk AX12-12 Stream Wifi 6 router. Will my range extender work with these routers?
A range extender should work with any router.
1 Reply
