fyredoggy's avatar
fyredoggy
Follower
Feb 10, 2020
router connection Nighthawk X6
Can I connect my router to my other router for better streaming?
1 Reply
  • plemans's avatar
    A better description of what you're trying can help.
    Are you planning on hardwiring in a router in a seperate area? That can be done but make sure put the other router in AP mode or you'll have a double nat.
    https://kb.netgear.com/30186/What-is-Double-NAT
    Are you trying to use one router as a wireless extender? If so, I'd recommend actually using an extender as thats what it's designed to do.
    What are you actually trying to do so we can better help you?
