JimmyW's avatar
JimmyW
Luminary
Feb 28, 2024
Router doesn't log me out and security question
My router is an RAX50v2 with Firmware Version V1.1.4.28_2.1.26. It seems that the Router does not log me out when I click the logout option under my user account icon in the upper left. After I click...
  • JimmyW's avatar
    JimmyW
    Feb 29, 2024
    It's the Bitwarden password manager extension. Usually, if the autofill-on-page-load option is selected (mine is), the creds are entered in the login fields as asterisks and I must click OK. However, with the router login, for some reason, login is fully automatic and the router page opens without displaying the masked creds or requiring my OK. I may question the Bitwarden forum about this, although it really isn't a big deal or a security risk.
    And because the Bitwarden extension loads as Chrome starts, it gives the impression that the router login creds survived a system reboot. They really didn't.
