JimmyW
Feb 28, 2024Luminary
Router doesn't log me out and security question
My router is an RAX50v2 with Firmware Version V1.1.4.28_2.1.26. It seems that the Router does not log me out when I click the logout option under my user account icon in the upper left. After I click...
- Feb 29, 2024
It's the Bitwarden password manager extension. Usually, if the autofill-on-page-load option is selected (mine is), the creds are entered in the login fields as asterisks and I must click OK. However, with the router login, for some reason, login is fully automatic and the router page opens without displaying the masked creds or requiring my OK. I may question the Bitwarden forum about this, although it really isn't a big deal or a security risk.
And because the Bitwarden extension loads as Chrome starts, it gives the impression that the router login creds survived a system reboot. They really didn't.
JimmyW
Nope. Mine stays logged on. While this may not pose a security risk, it is a bug that Netgear should address.
JimmyW
Feb 29, 2024Luminary
I have the Nighthawk app on my android phone, but don't use it.
- FURRYe38Feb 29, 2024Guru - Experienced User
Happens with different browsers?
Be sure to clear out all browser caches before entering into the routers web page.
I'd factory reset the router and setup from scratch.
- JimmyWFeb 29, 2024Luminary
I just noted that the router keeps me logged in even after I reboot my system. But the issue does not present in MS Edge-logout is clean and complete. So, maybe it has to do with a Chrome extension: I ran a clean install of Chrome portable, and the issue does not present. So, the first thing to try is disabling my extensions one by one. I reset of the router doesn't appear to be indicated.
OK, great to know about MS Edge and Chrome. Let us know if you find out anything with Chrome extensions.
