JimmyW
Feb 28, 2024Luminary
Router doesn't log me out and security question
My router is an RAX50v2 with Firmware Version V1.1.4.28_2.1.26. It seems that the Router does not log me out when I click the logout option under my user account icon in the upper left. After I click...
- Feb 29, 2024
It's the Bitwarden password manager extension. Usually, if the autofill-on-page-load option is selected (mine is), the creds are entered in the login fields as asterisks and I must click OK. However, with the router login, for some reason, login is fully automatic and the router page opens without displaying the masked creds or requiring my OK. I may question the Bitwarden forum about this, although it really isn't a big deal or a security risk.
And because the Bitwarden extension loads as Chrome starts, it gives the impression that the router login creds survived a system reboot. They really didn't.
Feb 29, 2024Guru - Experienced User
OK, great to know about MS Edge and Chrome. Let us know if you find out anything with Chrome extensions.
JimmyW
Feb 29, 2024Luminary
- FURRYe38Feb 29, 2024Guru - Experienced User
Interesting find. Glad you figured it out.
I guess you don't need to FR then.
- JimmyWFeb 29, 2024LuminaryActually, Birwarden is superb. The issue jere isn't really a problem. And I always fix my Bitwarden setup to prevent it.
That was one of the first thing I tried when the issue first arose. My phone, using chrome, requires creds to login to the router. Bitwarden is rather bulletproof. I have it on my phone, but use it only on a case by case basis; it doesn't stay open very long, like my Chrome extension does.
