Lilweezy83's avatar
Lilweezy83
Router Dropping Connection For Random Devices
Hello,
I've had an issue with my router since it was initially purchased where the Wi-Fi connection for random devices would just stop working. Other devices would work fine, but those items would just completely lose their connection and it would require a full reboot to get it back working. This has been happening at least every other day since I originally purchased the device.
I've gone through multiple cases with support and have tried resetting the router, a firmware update and changing the wifi channels. It was last reported that it was probably an issue with my ISP, but I've troubleshooted with them and nothing was found. I then switched back to my older router that this new was set to replace and my connection worked flawlessly for two weeks.
Please advise as now support will no longer help me.
Thanks!
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello,
    Has support been able to follow up on your support ticket recently? If not, I can assist with having your issue escalated.
    Christian
  • If you have “smart connect” turned on, kill it. It was screwing my whole house up. It was making my TVs, laptops, & phones jump from 2.4 to 5ghz and drop constantly. You’ll get much more reliable connections.
