jeepgod's avatar
jeepgod
Router drops my switch
Hello,
My wired switch, Netgear Gs605v5 drops internet after a few minutes, unplug it, it works for another few minutes. I have it wired to a Nighthawk AX3600. It's worked great for a year, now it has stopped working like it should.
I have updated the firmware of the router to version V1.0.12.120_2.0.83. I can unplug the switch from the router and then plug that ethernet cable into my pc and have internet with no problem at all. I have swapped out the switch and the other Netgear GS108 switch the does the same thing.
What can I do to correct this?
  • I've set the router back to factory defaults, still works the same. Wifi does work and has no issues. It's just the connection to the switch, it drops the switch after a few minutes.
  • FURRYe38's avatar
    What model router do you have?
    Be sure your using a good quality LAN cable between the switch and router. CAT6 is recommended.
    Does this happen with a different switch?
    • jeepgod's avatar
      jeepgod
      Router is a NetGear Nighthawk AX5 RAX41 5-stream Wifi Router
      Switch 1 is a NetGear GS605v5
      Switch 2 is a NetGear GS108
      I have tried two different CAT 6 cables, both will work plugged in from router to pc.
      I normally have just one switch in my office for 3 pc's.
      I have tried two different switches, listed above. When I plug in either switch, the switch will work for about 5 minutes, then looses connection.
      I have been using the GS605v5 for about 6 months now with no issues with this setup, I purchased it new along with the router above, since my wife now works from home.
      • FURRYe38's avatar
        AX3600 is a wifi speed, not a model#
        So both of these switches fail after minutes of being on?
        Do PCs directly connected to the router exhibit the same thing?
