Kiwi_ET's avatar
Kiwi_ET
Tutor
Sep 10, 2023
Router Fails to setup
I am trying to connect to my ISP (2Degress - NZ). The fibre network is run by a different com[any Northpower and they use Calix FSL modems. When I go through the setup using either the app or the rou...
  • Kiwi_ET's avatar
    Kiwi_ET
    Sep 18, 2023
    Solution found by looking at the ISP's supplied router setup. The problem was in the way the VLAN was created. They did not tell me which options to select so I never got it right. Using their router let me see how they required it.
