TomK12
Jun 24, 2021Aspirant
Router freezes
Hi I have my RAX120 for more den 1.5 years, and was very happy and satisfied with it until a few weeks ago the router has the latest firmware 1.2.1.22 but from time to time (sometimes a few weeks,...
Christian_R
Jun 30, 2021NETGEAR Employee Retired
Hi Thomas,
Did the issue began occurring on this firmware version?
Christian
- TomK12Jun 30, 2021Aspirant
Hi Christian
It occurs with the latest firmware (1.2.1.22) more often as with the previous firmware, I am sorry but I cannot say by sure when this problem started to begin.
because after this happened more often, I tried to get information from the router log, so I configured the router to send me the log by mail once a day. and I started by the end of march, and as I mentioned before, I am not sure when I did install the latest firmware, but I think it was sometime in April.
best regards
Thomas
- Christian_RJul 07, 2021NETGEAR Employee Retired
Hi Thomas,
You may try reverting to the previous firmware version to see if that helps with your issue.
https://kb.netgear.com/000062689/RAX120-Firmware-Version-1-2-0-16
Christian
- TomK12Jul 12, 2021Aspirant
Hello Christian
I installed now the previous firmware, and will check the next few days and weeks, if my problem is solved or not
Thank you for your advice in advance
I hope this will solve my problem
best regards
Thomas
