TomK12
Jun 24, 2021Aspirant
Router freezes
Hi I have my RAX120 for more den 1.5 years, and was very happy and satisfied with it until a few weeks ago the router has the latest firmware 1.2.1.22 but from time to time (sometimes a few weeks,...
Christian_R
Jun 30, 2021NETGEAR Employee Retired
Hi Thomas,
Did the issue began occurring on this firmware version?
Christian
TomK12
Jun 30, 2021Aspirant
Hi Christian
It occurs with the latest firmware (1.2.1.22) more often as with the previous firmware, I am sorry but I cannot say by sure when this problem started to begin.
because after this happened more often, I tried to get information from the router log, so I configured the router to send me the log by mail once a day. and I started by the end of march, and as I mentioned before, I am not sure when I did install the latest firmware, but I think it was sometime in April.
best regards
Thomas
- Christian_RJul 07, 2021NETGEAR Employee Retired
Hi Thomas,
You may try reverting to the previous firmware version to see if that helps with your issue.
https://kb.netgear.com/000062689/RAX120-Firmware-Version-1-2-0-16
Christian
- TomK12Jul 12, 2021Aspirant
Hello Christian
I installed now the previous firmware, and will check the next few days and weeks, if my problem is solved or not
Thank you for your advice in advance
I hope this will solve my problem
best regards
Thomas
- TomK12Jul 13, 2021Aspirant
Hi Christian
I already can say that installing the previous Firmware, does not help
since yesterday, the router freezes 2 times, no chance to connect with another device, nor with WLAN
only POWER OFF helps, dan then all logs are deleted, so I cannot try to find out, what event occurs immediately befor freezing happens
best regards
Thomas
