bbury10
Oct 28, 2021Tutor
Router getting full speed but not sending to devices - RAX50
Router - NETGEAR - Nighthawk RAX50 (AX5400) Wi-Fi 6 Route Modem - NETGEAR - Nighthawk 32 x 8 DOCSIS 3.1 Cable Modem -- Recently moved. At our previous home when i setup the internet, the router w...
Oct 28, 2021Guru - Experienced User
What is the model# of the Internet Service Providers modem/ONT the NG router is connected too?
Was it maybe WMM enabled?
Beamforming?
Try checking settings Under Advanced Tab/Advanced Settings/Wireless Settings...
bbury10
Oct 28, 2021Tutor
I bought the modem as well. Model number is CM1200.
"Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices" is enabled (green checkbox)
Not sure what WMM is. Looks like it might be equivalent of QoS on Netgear? It is not enabled. Right under it, "Let Speedtest detect my internet bandwitdh" is checked.
Would MUT have anything to do with it?
- FURRYe38Oct 28, 2021Guru - Experienced User
Yes, enable WMM. That should be enabled. Should see speed increase here.
- bbury10Oct 28, 2021Tutor
The WMM killed it from 150-200 down to 20-30. Going to keep plugging away and see if i can come up with something or might just bite the bullet on the netgear support.
