linkjankens
Jul 19, 2024Guide
Router is preventing website from loading properly
I've had a problem with my router not allowing specific sites to load images or styles. it's been doing this for *months* now. I've been seeing this problem all around the internet but nobody seems t...
linkjankens
Jul 21, 2024Guide
The firmware version is V1.0.16.132_2.0.92
I have a Netgear Nighthawk CM1000v2
I only ever use high-quality cables, always CAT6
Regardless of browser it still does this
And I did say earlier it happens on all devices that are connected to the router, be it wifi or ethernet
I never changed the configurations, I don't really know anything about ipv6 but here's the settings it has:
Internet connection type ~ DHCP
User Class ~ none
Domain Name ~ none
IPv6 DNS Address ~ Get automatically from ISP
Router's IPv6 Address on LAN ~ Auto config
IPv6 Filtering ~ Secured
I'll try a custom IPv6
Jul 22, 2024Guru - Experienced User
I would first try IPv6 disabled on the router.
Power OFF the ISP Modem and Router for 1 minute then back on.
If problem is still happening, factory reset and setup from scratch. A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the router and power it off. Power ON the ISP modem and let it sync. Then power ON the router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Or use the ERASE button on the routers web page to factory reset the router:
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- linkjankensJul 23, 2024Guide
IPv6 was off by default. Turning it on the first time was the only time I was able to access the site normally and it was temporary. I only got a week or two of access though. Still, I tried disabling, nothing. Turned it back on, nothing. I also tried doing Google's public IPv6 DNS and that didn't work
I did a factory reset where I unplugged the adapters for a half hour. I've already done literally everything in your post and even put that in the op. I imagine doing it a second time will do nothing but frustrate me more since I've had to relog EVERYTHING back into the wifi after making sure I cleared their connections first. Not doing it again
Status is goodlogs literally doesn't log anything when I try to access the website, I have looked before. Just posts some things about random dos attacks every so often. It's currently blank though even after attempting to reach the site repeatedly
- FURRYe38Jul 23, 2024Guru - Experienced User
So if you power OFF the cable modem, disconnect the RAX router, connect one wired PC to the back of the modem and power it ON, can you access this one site then?
- linkjankensJul 24, 2024GuideMate, I appreciate the attempt to assist, but did you even read my post? You've only made suggestions to do what I've already said I've done
