Wirelesseric
Dec 22, 2024Tutor
Router is RAEX 500 and Iphone 16 Pro 6G
So I have the RAEX 500 router and just purchased the new iPhone 16 Pro. when I go to connect to 6G, it says limited compatibility.? I have tried multiple settings to change and yet it still does this...
michaelkenward
Dec 22, 2024Guru - Experienced User
First try this:
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
Anything else is down to Apple.
Just another user with time on their hands.
- WirelessericDec 23, 2024Tutor
My Apple clients/ Devices connect fine using the 2.4 and the 5 GHz on this router. I'm not clear why it would affect the 3rd band only. I did try this settings change on my Apple device. Unfortunately, it didn't fix the silly warning sign from Apple.
Thanks for the reply!!
- WirelessericJan 05, 2025Tutor
I disabled all of IOS Wifi security features, and same results. I have WIFI 6 with the warning sign and it doesn"t show up as to what it's connected to under connected devices using a computer on the router. It's just blank in that spot when on 6G, everything else shows as directly connected or 2.4/5Ghz.
It's a strange problem, hope Netgear does a firmware update as promised.
Thanks, good suggestion!
