Wirelesseric
Dec 22, 2024Tutor
Router is RAEX 500 and Iphone 16 Pro 6G
So I have the RAEX 500 router and just purchased the new iPhone 16 Pro. when I go to connect to 6G, it says limited compatibility.? I have tried multiple settings to change and yet it still does this...
Dec 23, 2024Guru - Experienced User
the RAXE500's 6ghz is weird. Its not been integrated into the "smart connect" option for the ssid. While you can set it with the same ssid as the 2.4/5ghz, I'm not sure how this impacts its band steering since it isn't integrated. have you tried it with a different ssid?
Wirelesseric
Dec 23, 2024Tutor
I have not tried changing my SSID for the 6G channel, you think that will work? As apple is saying they all need to be the same? Thanks
