Wirelesseric
Dec 22, 2024Tutor
Router is RAEX 500 and Iphone 16 Pro 6G
So I have the RAEX 500 router and just purchased the new iPhone 16 Pro. when I go to connect to 6G, it says limited compatibility.? I have tried multiple settings to change and yet it still does this...
michaelkenward
Dec 23, 2024Guru - Experienced User
Wirelesseric wrote:
I never likes (smart connect) as in my experience everything usually defaults to the 2.4 channel.
That's down to your wifi clients. A more common complaint here is that everything connects to 5 GHz which screws up people who want their mobile on 2.4 GHz so that they can install Internet of Things (IoT) things.
Just another user with time on their hands.
Wirelesseric
Jan 01, 2025Tutor
My 2.4 Lot Devices are working fine, I don't have a lot of them. only 2 that are not hardwired into the router itself.
Thank you!
- FURRYe38Jan 01, 2025Guru - Experienced User
Can try. Probably won't matter.
